BelleSerene
I have an Ambassador rope cutter between P bracket and a Featherstream folding prop. Some twit, on disconnecting the prop shaft for alignment, has failed to ensure the fixed cutter was inside the striker plate on reassembly - so basically, the easiest way to fix this is while the boat's on piles doing antifouling, to disconnect the 4-bolt flange that connects the forward end of the prop shaft from the gearbox drive shaft, drop the prop shaft a couple of inches, locate it correctly under the hull, climb back on board and reconnect the flange. There are from memory four bolts ~4cm long, perhaps M10 or M8, going through this flange and fixing with (probably) nylon nuts.
Those 4 bolts: should they be torqued up to a particular level? Just done up as tight as two arms can manage? Or what?
