lexi
My Yanmar can start up and run 5minutes and sometimes to an hour, then engine note changes and slowly dies. If I open bleed on injector pump, it picks up and can then repeat the same symptoms, until I open again. My first thoughts are air coming in at CAV 296 separator. Not a sign of leakage there though. I also have one of these plastic Vetus tanks with the push on fittings.
An Old Salt in the bay with same engine thinks it is the return line. He reckons that the route back to tank is too long and uphill. For the same symptoms as I have had, he diverted the leak off the a catch tank. My CAV 296 has been refurbed with new gaskets done by the book , as has the whole fuel system with new fuel etc etc. It is all clean after a full rebuild. It is a fully rebuilt 16ft clinker launch.
I will try the catch tank trick, put some clear hose in before. IP and look for bubbbles, then maybe jury rig a gallon tank up.
Any thoughts on any of these moves appreciated.
