EdgarCove
Hello All....After purchasing a re-built Yanmar 1GM10 engine...it came with 'non-standard ' engine mounts ( circular bobbin type). After questioning this, the engine supplier agreed to send 'the correct' Yanmar type mounts.
My question is...as I understand it the '50' mount is the rear and the '75' being the front mounts...both of these being identified with a 50 and 75 stamping in the rubber respectively. Would I be correct to assume that if the ones being supplied don't have a 50/75 stamped in them they may be for the GM2 or 3...and if so..send them back?
Thank you.
Steve
Thank you.
Steve
