colin_dev
Hi,
I am in the process of replacing the coolant/antifreeze on my Yanmar 3YM30 engine. This is the first time I personally have done it on this particular engine. I am flushing multiple times with deionised water due to a change of coolant type, but that is really irrelevant to this query.
From the engine spec. the coolant capacity is approximately 5 litres and I initially drained around this amount, plus a little more from the caloifier. However, the refill only takes about 3 litres. Puzzling!
I have somewhat reluctantly run the engine a number of times, the last being for 10 minutes to see if it clears any air locks, but there was minimal drop in the fluid level in the heat exchanger. I have run the engine in idle, in gear and for a few seconds out of gear at high revs.
As I am flushing, I have now drained and refilled three times, each time only 3 litre or so goes in.
Anyone else incurred this or have a sensible suggestion on the cause.
The boat is a Jeanneau SO389 built in 2015.
Thanks. in advance.
If you respond please stay on topic.
Colin.
Thanks. in advance.
Colin.
