Wansworth
Browsing yachts as usual info about the engine would be interesting BoAt 1988 original motor,thanks
No ,I think it’s a single cylinder ,the add says 8cc,it being in Spain8 cu cm? Is it a model engine?
Thanks,I thought the cc bit was the same as hp……it’s probably that engine.It's surely got to be 80cc?
Or 8 hp which would be about right for a 1GM10 or similar predecessor.
https://www.yanmar.com/marine/product/engines/1gm10-marine-diesel-engine/
Even more of a tooth rattler than the Sole in the other boat. Bit underpowered for that boat but if in good nick will likely go on forever - noisily and slowly.
ThanksEven more of a tooth rattler than the Sole in the other boat. Bit underpowered for that boat but if in good nick will likely go on forever - noisily and slowly.
Well that’s encouraging ,just what I need
The GM and Ym series have a vertical cylinder .
Quite dated this one then?
You can tell whether an owner cares by looking at the peeling linings, flaking interior varnish and crazed hatch acrylics - or not , never mind the elderly engine.
“ There may be trouble ahead…”
Dont be put off by that "modern" thing. It really isn't, and it might have been a "joke"Yanmar YSM8 7HP. The 3rd generation of the YSE/YSB/YSM 8/12 single horizontal cylinder engines, 'M' standing for 'modern'.
