Moonshiners
My dad has a pair of Yanmar 4LHA's on a nimbus 350 (2005) since the boat has been on the hard and been serviced, new prop bearings etc... the port engine (only) has develloped an intermitent problem. The engine will drop from cruising revs (3500) down to 800 for anywhere between 8-20 mins then come back up to normal speed. (also happens at low revs) As it's an intermitent problem, I've never been on board while it's happened. I'm heading up later to check out and change the (newish) primary fuel filters.
The problem seems to occur when it's rough and choppy, idicating movement of something may be the cause. Have had marine engineers on board, but problem did not arise at the time during test and no issues were found.
Service engineers have not made any effort to help sort out the problem.
But does anyone have and suggestions on what it could be, or things worth checking out?
I'm not well up on diesels, so all experienced thoughts welcomed.
Need to get it sorted ASAP and cross channel trip planned shortly...
Thanks.
Thanks.
