yanmar 4jh 110hp. gearbox.
beebok
27 Feb 2008
hello all some advice please.
when selecting forward drive it will not engage gear,
it seems to jump and knock and you can see it quite clearly at the gearbox trying to engage.
this is not a continual problem.
if i select reverse and then into gear it works ok.
the sad part is that this is the second gearbox that appears faulty,
original and replacement.
the set up is a folding max prop through drive shaft and aquadrive.
prop check so many times and thats ok.
aquadrive of and check by daglow engineering and thats ok.
new prop shaft.
any opinion please!!
