Yanmar 3YM20 primary fuel filter
mcanderson
24 Sep 2006
London/SofF
My primary fuel filter has the filter element marked up as a MANN FILTER P917. I wish to replace this at the end of the season, but a quick google search only throws up US stockists.
The engine is fitted in a 2005 Beneteau 323. I'll try calling Foxes today.
Any sugestions?
Close
Thanks Full Circle, but that's the secondary filter. The primary is a canister filter than has an alloy bowl and then the filter canister fitted. The one you show, sits inside the secondary filter housing.
According to this site:
http://www.filtrauto.com/catalogues2008/FO/scripts/f_cat_rech_correspondance.php?lang=GB
the Fram equivalent is C1191, and the Fleetguard equivalent is FF167. The Fleetguard site ( http://www.fleetguard.com/catalog/p...Type=Fuel, Cartridge&partflag=0&currentPage=1 )gives more details to help you to check if it's correct, as follows:
FF167
Fuel, Cartridge
End 1 ID 18.8 mm (.74 in)
End 2 ID 38 mm (1.496 in)
End 1 OD 88 mm (3.465 in)
End 2 OD 84 mm (3.307 in)
Overall Height 72 mm (2.835 in)
