cdrmike43
New Member
Occasionally I have had difficulty starting the engine when hot. The starter tries to spin the engine halfheartedly but not enough to get it going. I have then had to lift one of the decompression levers and the engine then spins over freely and bursts into life and I can then close the lever. This has only occurred when the engine is hot. When cold the engine starts readily. The start battery is new and fully charged so this phenomenon is somewhat of a mystery and the local Yanmar Agent is also puzzled. Is there someone out there that has experienced this problem? I previously had a common Yanmar start problem with intermittent starter button operation but since running a new thicker wire from the start button to the solenoid, the original problem has gone away.
