Crazy-Diamond
I’m motoring along the Essex coast this morning, very little wind. My cooling alarm went off on the engine panel. Initial checks show nothing wrong. The strainer is not blocked, with water flowing through, there is water coming out of the exhaust just fine. My gut feel, when opening the engine bay, is that the engine is running perfectly normally, and did not smell hot. I’m a bit baffled.
Could it be the warm weather? The sea temperature is quite warm (22 degrees). I had been motoring for approx 3hrs at 2500rpm.
little bit worrying as I’ll be needing the engine to get back to the shore!
Any thoughts?
I’m letting it cool and then I will open the heat exchanger pressure cap to look for any problem. The level of water in the expansion tank is normal
Thanks,
Giles
Any thoughts?
Thanks,
Giles
