yanmar 2qm 15 owners
mtb
30 Jan 2002
I had been looking for over a year to get a spare head gasket for my engine and put a search on ebay so I got emailed if one turned up. One did last week and I got it, this morning another has been put on ebay item number 124060-01331 their £58.86 including post you can get em from the states but at a higher cost with post. original yanmar not a copy
cheers
mick
cheers
mick
Thanks- I hope I won't need one! I've bought engine mounts for it for 25% of the Yanmar price, from AVIndustrial and anodes from Ebay (Yanmar packaging 200300 part no) for 6.50 each delivered.
Have you got the pdf manuals? I've found three, one users two good workshop.
ps the Kanzi gearbox needs ATF oil not engine oil!
hi nick
Mine came with a hurth fitted to the kanzi bellhousing but the box had a worn input spline as I think the prop was quite large that it was fiited with, the other clue being the ratio of the box wasn't right for the colvic. So I swapped it over with the original box that came off the boats petter twin but as I didn't want to strip the box and wasn't able to test it untill it was fitted, I now find the output seal leaks so popped down today and took the box off to strip it and fit what ever parts are needed.
I also had the flywheel machined to take the petter drive plate because the original yanmar drive plate was so badly worn
Just incase your unlucky with the raw water pump on yours I have fitted a johnson pump which was simple enough to do using a 4" bit of angle iron with slots cut into it then bolted onto the original mountings for the yanmar pump which by the way uses the same impeller as the johnson
cheers
mick
hi nick
cheers
mick
Thanks for the tip- sounds like you know these engines very well!
