vas
evening all,
my generator 2GMF continues to give me starting problems even after the full rebuilt.
fuel layout is:
tank level currently slightly lower than engine LP and HP pumps
3m new hose to LP pump
New 400mm hose with banjo to compression fitting (or however you call them with the conical face, no washers, or anything needed to seal)
CAV296 filter
New 40mm hose as before the filter to HP pump.
CAV has replaced the original yanmar filter as the bleed screw threads were stripped and wasn't generally happy with it, feeling it was leaking (had the same issues)
Now we have the following:
works fine as long as you bleed it at the HP pump inlet (release the banjo, 3-4 turns of the starter, then fires)
works as long as you want no problems, never dies.
leave it for an hour or two, fires up on first push of the button, fine.
Leave it for 5-6h (or overnight) simply wont start unless you bleed again.
Have tried all sorts of things, failed miserably.
So, today went a step further:
replaced all copper washers on banjos and connectors with these metal/rubber combo things (sorry forget the name) all brand new.
replaced the second inlet of the CAV filter with a pickup for a carburetor style pressure/vac gauge.
Bled the thing again, fired straight up, gauge showed 3.5psi whilst running at 3K rpm (old school 2pole generator) going up to 4.2psi when I turn off the engine.
Checked three hours later before leaving the boat in the evening, pressure was down to 1.5psi, engine fired up straight away (temps were down to 30C) pressure again up to 3.5psi.
Left it, will go back in the morning, I bet it wont fire up again and the gauge will show 0 if not - ...
Considering I cannot spot any diesel leak (and I've spent a fair amount of time searching!) I feel the only two candidates are the bloody filter (I really hate it!) or the LP pump.
I've taken apart both of them, reassembled, nothing odd in either.
I've also bought a 1/2 USwhatever thread stop cock so I can add it either between LP and CAV or CAV and HP pump.
I'll try fitting it between LP and CAV tomorrow and see what's going to happen.
Am I right in assuming that if pressure doesn't drop I better replace the LP pump as the non return valves are leaking fuel back towards the tank?
Oil level is steady and doesn't change, so cannot believe the membrane leaks down to the sump.
Before forking out the 60-70quid of the LP pump, is there an easy way to test the non return valves in this thing?
Have compressed air onboard, was thinking if I could carefully pump backwards from LP outlet some air and see what happens
When I opened it up, membrane looked good, little crude in there (v.little tbh) and used new gasket sealant before putting it back together.
from what I can remember, the non return valves where nice and clean.
Further I cannot trace and diesel around it or on either banjo...
ideas welcomed
V.
fuel layout is:
CAV296 filter
ideas welcomed
V.
