CLP
I'd really appreciate the views of learned forum members on recent problems staring my Yanmar. I'll be as brief as possible but the tale so far is:
The engine was installed in 1998 and has performed without trouble until this season.
It's total running hours is around 2300 hours.
I've maintained it throughout as per the Manual.
This season, getting it to fire from cold, has progressively become more difficult. Air seemed to be the problem and the engine fired up after a minute or two spent bleeding the fuel line. Once running the engine performed fine and would start ok if restarted within about 6 to 12 hours of stopping.
I cleaned out the tank and fuel lines, checked fuel line connections, replaced filters, washers etc and put new fuel in but this didn't improve things.
A month ago things got harder and the engine refused to fire at all.
The yard's engineer got it going but only by using Easy Start and when cold, the problem returned.
I left the yard to investigate further.
They checked the fuel lines, tested the injectors, cleaned out the exhaust, tested compression and found low compression in one cylinder.
The head came off and the head gasket was found to be blown, so that's been replaced and everything put back together BUT...
The engine still won't fire.
So the yard are now scratching their heads too.
Does anyone have any ideas???
Many thanks
Many thanks
