vas
evening all,
I have a MASE 7 generator which runs of a 2cyl yanmar 2GM20F. F means it is closed circuit cooling.
Generator is on a motorboat, sitting above w/l, has a silencer and exhaust is above w/l.
Yanmar has 1K hrs on the clock, had to rebuilt the raw water impeller (shaft shafted), and also had to replace the starter motor due to extensive cranking by myself and PO.
I always had problems with that motor starting from stone cold and especially if left for a day or two.
What I have done:
When I do all that, engine will start OKish, when I leave it say for a day I'll need 3-4 3sec crank sessions to fire up.
Of course if I run it once, then within the next few hours it will start on first crank.
Some more observations:
Ideas on where to look at are very much welcomed. I hope you wont suggest I have a tiny leak as I'm running out of ideas, paper towel is dry, engine is dry, cannot see somepoint where it would leak tbh!
Next (and only atm) actions to take are:
replace lift pump (assuming output is indeed low and that can relate to the issue) would like confirmation that it's worn though as I've no idea how much it is...
check and measure injectors (I'll do that next month when the engineer will come to remove the IVECO injectors for testing) but not sure that would help.
Projected generator use is not a lot, a few half hour sessions at night to cool the boat down before going to bed (if in a marina that is), 10-15h per season for the watermaker and immersion heater.
cheers
V.
What I have done:
- replaced the imho useless yanmar main filter for a CAV296 one (it's not leaking!). Fabricated a mounting plate to fit in the space of the old one.
- changed oil and oil filter (ok, not related but did it nevertheless)
- removed and replaced all copper washers on the banjos along the diesel line to the pump.
- bled the engine numerous times, at the beginning I had problems with a piece of hose that was slightly oversize and would leak (CAV to pump) replaced with right dia hose, eventually all is dry and clean
- Bleeding was done after reading manuals, looking umpteen how-to videos on youtube and employing common sense:
- first from lift pump to CAV,
- then on the pump input (keeping current to the stop solenoid which is mounted there else diesel wont go through...)
- then cracking open the pipe coming into the two injectors one at a time
- then the return pipes.
- Motor runs at 3K rpm, even from stone cold. I mean governor is winded and stop is locked up there. I find it harsh and awful for a tiny motor to work like that but I guess all generators work like that although most recent ones are 1500rpm jobs and not 3K
- I'm not impressed with the lift pump output but my only other experience with diesel engines is the 6.7lt IVECOs, and yes I do know and turn the flywheel in order to get the maximum travel and output of the lift pump. I mean replacing the CAV, I probably pumped a 80-100times to bleed the filter!
- Tank pickup is through a smallish day tank, exactly where the two main engines get their fuel so no issues there. Fuel line is new and only 3m long. Lift pump approx 40cm above bottom of tank, or at the half full level- doesn't help no matter how much fuel is in the tank
- getting air out of the main pump is fine, but opening up the return nuts on top of the injectors I practically get no diesel coming out (with engine running at 3K, but also at idle) I would have thought there'd be plenty of juice going back to the tank.
cheers
V.
