david1993hunter
New Member
Hi, I have a Yanmar 2gm20 in my boat from around 1999. It has never smoked except at max revs, until recently when above a third revs it gives out light grey smoke, getting darker as revs are increased. I read in the Yanmar manual that this could be caused by a clogged exhaust elbow. I removed the exhaust elbow which wasnt blocked, however on inspection, I noticed a tiny pin hole on the inside of the elbow, not the outside, approximately 1 inch from the water inlet, towards the end of the elbow. Would this cause the engine to smoke? Any help would be greatly appreciated, trying to go through a process of elimination before removing injectors etc. My prop is dirty and I will need to clean that, and it is probably contributing to the darker smoke, however I haven't had such an issue before even with a dirty prop. I had the head reconditioned 2 years ago with new valves etc.
