GeorgeTina
Hi, I have a small oil leak from the front camshaft oil seal on my 2GM20 (sea water cooled). Does anyone know if is is possible to change the oil seal from the front of the timing case cover without removing the timing case cover as I am in Croatia and spares for the Yanmar (Like gaskets) are impossible to source locally. I have been given the part number of the seal as 121450-01801. Anyone know if this is correct and what size it is as I am sure Yanmar do not make oil seals so it may be possible to source a seal from a bearing and seal shop if only I could find one. Otherwise I will have to keep adding oil and cleaning up the drips !!
Thank you
Thank you
