Saddletramp
I am in the process of buying a Sadler 32 with a 1982 Yanmar 2gm.
2 points to consider:
1) If there is anything obviously wrong I want to know so that I can negotiate on price and get it fixed.
2) I need to know the chances of the engine working on a delivery from the Exe to Chichester.
Should I ask the yard to carry out a compression test? Would this give me a reasonable indication of the engine condition.
Once I have bought the boat I intend to check the fuel lines and replace filters.
Water, I will change the impeller check pipes.
Take off the elbow and clean it out as I understand they can fail.
Check air filters.
Is there anything else I should do, assuming a compression test was okay?
Check air filters.
