petermills
Active Member
I'm pulling my hair out over this.......
There is no guage - just a warning light and buzzer which operate when overheating occurrs.
With the disconnected sender in a pan of overheated water, there is continuity between the body of the sender and the single terminal. When the water cools down, the continuity is broken.
Temperature sender has just one wire connection. With the Starter switch in first position, the oil pressure and charging lamps light up and the buzzer sounds. The coolant warning lamp does not go 'on'.The temperature sender wire has 12 volts on it. Can someone explain what happens to this 12 volt supply when the engine overheats??? To me, it seems that the 12 volts would go direct to earth when the switch senses overheating.
Any ideas ?????
Any ideas ?????
