Yanmar 1GM10 Panel - Lights question
weaver_fish
10 Aug 2005
Quick and simple one.
When I turn the key, I get the oil pressure lamp lit on and the charging warning lamp lit and the lovely buzzer sounds... I notice that the water temperature lamp stays off - is this normal, or should it also light temporarily before the engine is run?
Cheers.
According to my GM series operation manual (page 20) when the key is turned on the oil pressure and charging lamp should light but not the cooling water temp alarm lamp. There doesn't seem to be a facility to test this lamp other than by shorting the terminal (white and blue wire) to ground.
