coaster63
Yanmar 1gm10 - engine oil change mod, I've never been happy with the extractor method of removing oil ,ends up messy & not convincing all out , I have on occasion used the removal of the plug holding the pickup strainer that also can be messy as it squirts towards you followed by the strainer .so this layup I've opted for a mod having removed the sump anyway for a proper clean out (luckily long keel so plenty of room ) I've added to the sump what I had surplus anyway to fashion a sump drain
an angle grinder disk nut (you'l now what it is in pics) with 14 mm bolt & sealing washer for draining , so no welding /tapping to do, 4 small 4mm holes +15mm hole ,30mins sorted.
pics -- https://flic.kr/s/aHsm8v9Cxd
