Sidestep
New Member
I’ve managed to remove both rubber seals from the pump body but I just can’t get the new smaller rubber oil seal back into the raw water pump body. I watched the YouTube vids plus other forum posts and it looks like you should be able to just place it in by hand and finish off with tapping in by hammer against a suitable sized socket.
I’ve tried this but only ended up destroying the new seal as it doesn’t want to fit into the grove on the body. I see there are 2 different seals available but they are meant to be interchangeable.
Im sure all the old seal has been removed so asking if anybody has any tips on re seating this seal after I’ve managed to obtain a new one.
