blackbeard
... so, following much advice on how to do it, I have begun to partially strip down the engine preparatory to taking the head off and getting rid of what I suspect to be a great deal of carbon.
I have got as far as the valve gear which I now need to take off the engine. It's held in place by a single nut , which I now need to remove and to then remove the valve gear prior to lifting off the cylinder head.
Problem is that I can't remove the nut. I have tried WD40, PlusGas, heat (carefully!) and brute force, but the nut will NOT turn - seems absolutely solid.
Can anyone help? As a last resort, is it possible to remove the head without taking the valve gear off?
