RomanDesign
New Member
Last season I had a problem with my 1989 Yamaha 9.9 4-stroke I bought with my Mac 26D 3 years ago. It became very unstable at idle and low throttle - sputtering and stalling unless I give it a little gas. Sometimes after starting and running for a while, then sailing, it would not want to start again, requiring a few tries and extra throttle until it started. It's used only a few hours in a season. It was fully serviced before I bought it and insides look like new for the most part. I replaced the impeller when I bought it. Yesterday when I got it out of my basement where I stored it for the winter, I changed oil in upper and lower units, changed spark plugs, that didn't help.
I bought carb cleaner spray and tried to clean carburetor that way - so the short version of my question is: is it good enough based on how it's running in the second video below (around 9 minute mark), or should I disassemble and attempt to clean the carburetor manually?
Please look at the video: you can see uneven detonation - it is shuddering neurotically, then after I put it to forward gear it becomes unstable and eventually stalls. This is before I sprayed any carb cleaner:
I bought carb cleaner spray and tried to clean carburetor that way - see video below, it was difficult not to let the engine stall and I could not do it continuously like instruction said, or the engine would stall for sure. I did it several times, using about half or more of the can. Look towards the end of the video (around 9 minute mark) - I still see some uneven shuddering but I let it run on lowest throttle with forward gear engaged for 10 minutes and it didn't stall. So it looks a it's better now, but I'm still not 100% sure if it's completely fine. Still vibrates kind of unevenly, but didn't stall at least.
So my question is: does it look normal to you (as of the end of the second video)? Or should I do something else? Should I try to adjust idle with the screw? Disassemble carburetor and manually clean it? Do anything else? Or is it OK as is?
My worry is that if I adjust idle to higher throttle - it would put a larger load on gears when switching to forward or reverse from neutral. Also when hoisting sail or reefing under motor or docking I want as slow speed as possible, so increasing lowest throttle is not desirable. But I'm worried if while docking or maneuvering in tight situations the motor quits on me at the worst moment - I'm gonna be in trouble.
