Adonnante
I have two Yamaha FT9.9 outboards on my catamaran. One of them has repeatedly over the last 18 months needed to have the adjuster extended to enable me to engage reverse. I have now reached the limit of the adjustment and have been searching for the cause. With the remote cables disconnected the out board behaves perfectly engaging both forward and reverse, with the cables attached the gear change lever on the outboard moves noticeably less when selecting reverse. The bracket that the remote cables terminate at on outboard is not bent and attached firmly. I can only assume that the remote control in the cockpit is not giving sufficient throw in reverse. Any advice on what to check in the remote control box would be most appreciated as I've never had one apart before.
Peter.
Peter.
