Yamaha 5hp 2 stroke-weak spark
  • Thread starter Thread starter C08
  • Start date Start date
C08
8 Feb 2013
This engine was used as a reserve engine before I bought it and I have never used it but ti ran fine 3 years ago. Done very little hours by the look under the cover.
No start and sparks are barely visible. So either no volts to drive the CDI unit or a dead CDI.
There are only two wires for the CDI, a live and earth wire. How can I check this with a meter?
See the CDI Electronics trouble shooting guide
https://www.cdielectronics.com/wp-content/uploads/2016/12/7th-Edition-Troubleshooting-Guide_RS.pdf
or the service manual to which a link was posted on here a few days ago ( Sorry I dont have the link .. I downloaded the manual!) **
You will need a "peak reading" meter, or a DVA adapter for an ordinary meter ( easily made if you can solder a few simple components together), for the procedures described in the CDI guide
Or the special equipment described in the Service manual
For a start perhaps check the coil resistances they might identify the problem
BUT you lost me at the point whre you said only two wires for the CDI unit ....
** http://www.johansilen.se/Manual1/Yamaha 4AC Service & Repair Manual.pdf
The spark on my malta is difficult to see and is I belive a characteristic of the smaller yamaha's.
Thanks for that, got a Malta on the bench with no spark..
D...oh. Because the ignition coil has CDI on it I assumed that was the CDI and the other plastic block was just a termination/connector box not the CDI. It gets expensive fault finding by substitution! Perhaps I am expecting to see a better spark than they generate, certainly barely visible and not across the spark gap with a new plug, just to earth with a tiny gap.
If it wont jump 8 mm there something wrong
Time make a DVA adapter and get troubleshooting
