Yamaha 4hp Gears difficult to engage
nyx
New Member
15 Apr 2009
chichester
i have a 1994 single cylinder 4hp 2stroke Yamaha
its been perfect but today i had to try many times to engage either gear.
it can't be forced into gear by using excessive pressure on the lever but if i give the prop a wiggle it engages fine with fwd and rev gears.
any one know how to diagnose the problem and fix it.
kind regards Nick
The gearbox will only engage when the shafts are at certain angles to each other. When the motor is running, it soon finds a point where it will engage. When stopped, the prop may need to turn relative to the engine. Otherwise the drive dogs will not intermesh.
Sounds like the selecter wedge may have burrs on it or the rod down the leg is jamming or linkage under the cowling. You need to check the linkage first before stripping the lower unit and checking that the dog clutch mechanism is free to move.
You probably have to open up the gearbox to check. It's quite easy: prop off, undo the two bolts on the flange and pull it out. You'll probably find a dearth of oil and lot of crap in there.
