00Si00
Active Member
I thought i'd offer up a solution to anyone who has never taken
apart a carburettor, namely from a Yamaha 4hp circa 2009.
Here is a link to the online album, its public so anyone can access
it.
https://picasaweb.google.com/114588...hpStripAndClean#slideshow/5723199317737073426
Picture quality is not great but should give enough confidence to give it a go!
I might as well add that removal of the carb is a piece of cake. Remove plastic lid/casing.
Remove 2 10mm bolts recessed in the air intake underneath the 2 plastic caps
The long bolts hold it all in place. I used a cheap 10mm socket bought from
http://www.maplin.co.uk/58-piece-ratchet-handle-screwdriver-bit-and-socket-set-99694
Be careful as you remove it all as bits will fall off (spacer, 2
gaskets, bolts and bolt spacers. Don't drop that little round o-
ring seated in the air filter.(Don't ask me how I know).
Did I forget to mention that the whole thing is left to soak in petrol and flushed with carb cleaner?
it.
