MAURICE
Hi
Im trying to change the impeller on this outboard. Ive got as far as undoing the two small bolts holding the impeller cover on and can lift up the cover a small amount but I cannot get the cover over the metal rod which turns the gears. Is there a small scew or bolt holding this rod onto the gears or should the impeller cover slide up over this rod. Ive done a 4hp and that just pulls up.
