labougie
Just acquired a 1973 Yamaha 2hp which seems to run fine. My only query is the amount of cooling water I can see coming out. According to the manual, it doesn't have a jet of water coming out vertically below the engine, rather it has four "pilot outlets" in the leg, which are sending out only the occasional spit of water. Should I have a good flow of water from these holes? There also seems to be some pressure escaping from the pilot outlets as well as a little water. Have I got a crusted up cooling system? Have I got a head gasket problem? Thanks in advance.
