Andrew_Trayfoot
Any suggests as to why my Yamaha f2.5 outboard will only run with the choke on?
Could be a blocked idle jet .
If you're over Lewes (Brighton) way any time, I have an ultrasonic cleaner which is made for this part of the job.My usual method which works an absolute treat is to remove the carburettor, don't buy any of these fancy carb cleaners just remove the jets and the float bowl. Place the entire contents in a pan fill with 6 parts water and 1 part lemon juice or distiller vinegar and simmer for 20 minutes it will remove every spec of vanish and grime. Rinse parts in clean water, dry and reassemble. I have fixed over 30 outboards using this method over the years
Then hide the pan from the missus as it may smell a little!
More to the point, how will you get rid of the smell of the vinegar from the carb?
Worked a treat...
but the vegetables with lunch today tasted funny
