Yakker Yakbitz to emTrak connection
mnrkks
5 May 2022
Hello All,
I hope you can help me :) I need support for the Yakker I have bought.
I have an AIS from EmTrak B923 model and it has output wiring as below,
Can you please help me which cable I need to put to the Yakker Rx part to get the AIS data in Navionics application in my ipad?
I tried several cables but I could not get the data.
Thanks for you support from now.
Best regards,
Onur
mnrkks
5 May 2022
You need to use port 1 NMEA 0183 TX + (Marron)
and
You need to use port 1 NMEA 0183 TX - (Azul)
Hi Paul,
Thanks for help, one clarification, NMEA 0183 TX - (Azul) should go to the GND in Yakker? Because I connected negative from the battery to that. So should I disconnect battery negative and put only NMEA 0183 TX - (Azul)?
Thanks a lot
PaulRainbow
16 May 2016
Suffolk
Hi Paul,
Thanks a lot
Connect the battery negative and the NMEA 0183 TX - (Azul) to the Takker ground terminal. Set the baud rate of the Yakker to 38,400
