Yachtmaster question #6
Phoenix of Hamble
28 Aug 2003
East Coast
mishapsandmemories.blogspot.com
I haven't done one for a while.... /forums/images/graemlins/grin.gif
Pete's long anticipated crossing over to Niuewpoort in Belgium had got off to a bad start after finding the previous evening that the main engine battery had failed. Given that the services battery was also of some age, prudence suggested abandoning the night passage and waiting until the following morning, replacing the battery, and setting off for a day crossing instead.
The following morning, with new battery fitted, and working, a quick check of the forecast suggested a North Easterly 3 to 4, perfect for a good broad reach over to Belgium, and also suited to the crew of 4 strong and fit people on board.
So, by 10h00, Pete slipped the lines for the 75nm passage.
The forecast proved to be quite accurate with a wind perhaps tending towards force 4, and before too long they slipped through the Southern North Sea TSS, just north of the busy Sandettie Junction, without hardly seeing a ship, but the wind had been steadily building and had swung round to a North Westerly, perhaps even more Westerly than that, making the course very down wind. This combined with a tide turning to flow north again had caused a sloppy and unpleasant sea state.
An hour later, it was turning towards dusk, and a full Force 6, gusting 7 was upon them, with a rapidly building sea. Pete was starting to worry about his pilotage for approaching the Belgian coast, just 15nm off, with its notorious shallows and sandbanks in this wind when there was an almighty bang and the boat rounded violently up into the wind where it sat with the sails flogging..... a glance behind them and Pete could see a large log and the remains of his rudder drifting away rapidly.
In a panic he ran down below to find the rudder shaft still secure in its mount, and no leakage, but absolutely no sign of any steerage at all....
What should Pete do next?
Bajansailor
27 Dec 2004
Marine Surveyor in Barbados
Simple. Steer with the Hydrovane rudder. Like any other sensible sailor, he installed a Hydrovane some time ago, and it fortunately was not clobbered by the log that took out his (unsupported) spade rudder.
The only reason they were not using it at the time was that they had lots of crew, all of whom were keen on steering, especially as in those conditions (broad reaching in a F 6 to 7) the Hydrovane might have had some problems unless they were just sailing with a relatively small headsail.
Yes, I know this is not the answer you are looking for - all the Tom Cunliffes on here will come up with much more sensible suggestions!
jimi
19 Dec 2001
St Neots
Get on the radio and ask for help then f#rt about trying emergency rudders to try and keep off the lee shore whilst awaiting a tow
Richard10002
17 Mar 2006
Manchester
a) heave to and start the engine, get all crew on deck with lifejackets and harnesses, all to be clipped on.
b) Pan Pan VHF call, (possibly Mayday - see below).
c) Attempt to make a jury rudder from
1) spinnaker pole and a door, or part thereof
2) Drogue running from the end of the boom
3) Steer with the sails
If it works, get as close to a bolt hole as is safe, then ask for a tow. If it doesnt work, ask for a tow.
At any time, if the situation threatens life, escalate the Pan Pan to a Mayday - the first call could be Mayday if there is a danger of being swept onto a bank or whatever.
Right or wrong, that's what comes to mind
Neddie_Seagoon
2 Apr 2006
IoM
www.yotblog.com
Well, if Pete were sailing my previous boat he'd just get the spare ("emergency") rudder from its locker, and hang it on the transom mounts waiting there just for that purpose....
Failing that I guess the tender has oars........ no?
Time to get a bucket out then /forums/images/graemlins/laugh.gif
Phoenix of Hamble
28 Aug 2003
East Coast
well, its a start... in writing the question, my thinking was, as Jimi has mentioned, the priority was to be very aware of the dangers of the lee shore off Belgium....
So the initial action has to be to prevent any further progress towards that Lee shore...
Merlin29
1 Mar 2007
Solihull (Boat - Southampton)
At the risk of making a fool of myself...I'm new to this lark you know...but for me this would put me out of my comfort zone. Here's what I think I would do.
1] Establish my position and make a pan call
2] Get all crew to wear their lifejackets and remind them again where the safety equipment is including white flares
3] Think
4] put on any lights that will help maintain visibility
5] Think
6] Continue to observe position. The northerly tide combined with westerly winds is going to take me slowly towards a lee shore. This is not "iminent danger" to life or vessel, but it will be iminent soon!
7]Think
8] realise that there is probably a flag or signal that I can fly to show my predicament but that even if I look it up I don't have said flag or signal on board
9] Think
10] realise that danger is iminent and upgrade the pan call to a mayday.
Go on, be brutal....tell me why I'm a fool.
M
Sans Bateau
19 Jan 2004
Get the warps out of the locker and tie (bend?) them together, attach that to the end of the anchor chain to increase scope and decrease snatch.
Or if he has a kedge, use that rode attached to bower anchor warp.
