jneale
Chain does'nt break. - Probable cause was failure of the anchor swivel. Check the M8 recessed bolts, - mine went rusty and suspected they were chrome plated iron - I think there was an earlier post of this some time ago.
Chain does'nt break. - .
Oh yes it does. Seen two in the last two years. Both about 10mm one was worn and rusty the other still had some galvanizing on it.
On the subject of shackles and swivels failing, a substantial percentage of moorings laid in the Southern Windwards have failed. Some in less than a year. If you are forced to use one back down on it hard and snorkel it if you can.
Weakest link undoubtedly is the connector? That said of course chain can break, too much strain or corrosion.
The best connectors are a lot stronger than the chain.
