Rebel Rebel
HI all,
Recently installed a XM DSC VHF onboard with a new Vtronix whip antenna at mast head and new cable run to the radio.
Upon testing it appears that I can transmit clearly but I could not receive, I get distortion / static / white noise instead of words but silence between the words. I had the squelch dialled up to just eliminate background static.
I then discovered that if I kept the volume really low I could make out everything clearly from a nearby testing handheld and from other radio traffic in the area. Obviously this is no good as engine noise / wind noise would mask the message, but it suggests that I can receive ok.
I have double checked all connections at deck level and even ran a separate cable and connectors to the foot of the mast with no improvement.
I'm guessing it is perhaps a speaker issue? The volume is not the same as gain on the signal is it? It shouldn't introduce distortion at low levels. My next step is to try an external speaker or maybe headphones to test.
Can anyone help me troubleshoot this issue? Unfortunately the radio was a boat jumble buy on my behalf by a friend, although it was meant to be brand new, so no receipt, no warranty, no luck!
Hope you can help,
Cheers,
mArk
Hope you can help,
Cheers,
mArk
