Spicemariner
I bought a boat which was fitted with a Link 10 battery monitor and a Sterling Pro-digital battery charger. Link 10 displayed voltage OK but only displayed amperage when connected to shore power and the battery charger switched on and then only as a positive. The positive reading increases as more draw is taken, although the battery charger hasn't increased its input. We have rewired and had the wiring checked by a marine electrician it but all to no avail does anyone have any ideas. Xantrex haven't replied to emails. Put simply
1 All the wiring from the shunt to the Link 10 is correct and has been checked by a marine electrician.
2 Volts are displayed correctly, whether charger is on or not.
3 Amps are only displayed as a positive when the charger is on but increased draw, shows an increased amps positive.
4 Amp hours only increase and there is no countdown when the battery charger is switched off.
