Xantrax battery monitor... battery capacity
Tomahawk
5 Sep 2010
Where life is good
As always this has probably been done before, but the search function on this forum is so "interesting" I can never find the answer I want..
Have changed the batteries on my tub. The new ones have a slightly different capacity... I can easily change the rated capacity on the Xantrax.. but I don't know which so called capacity rating to enter..
The battery is marked with C5, C10 C20 and C100 ratings.. all have a different number.. Which one should I use?
You use the C20 rating.
What they said: it's more casually referred to as "the 20 hour rate". Plenty of stuff on line if you need a fuller explanation.
Searching: yes, the on-site facility is pants. Use Google or one of the other biggies specifying "ybw.com" and you'll have a far less "interesting" time.
