lpdsn
I've been uploading waypoints from OpenCPN to a Garmin GPS (158i). Although the OpenCPN manual says that it is necessary to enable Garmin Propietary sentences on the connection I found that didn't work but ordinary NMEA0183 WPL sentences did.
So I managed to get the waypoints transferred across, except that only the first six chars of the names were used. The GPS supports ten chars so I had to manually edit the names to add the extra chars.
The trouble is I can't find where the six char limit comes in. It doesn't seem to be explicitly a limitation of the NMEA0183 WPL sentence according to the various bits and pieces I've found with a web search. It would certainly be easier in the future if I can transfer waypoints with full 10-char names.
Does anyone know where the limitation is and if there is any way around it?
