DaveNTL
Been charging the house batteries via the genny / mastervolt charger, and then the main engine / alternator.
2 gel batteries cells 165 AH each in parallel, so 330 AH.
I get the feeling that they aren't holding a charge or charging up as they should.
This what happened:
Charging through charger
Time (of day) / Amps (total capacity)
4.45 / 242.5
5.15 / 243.4
5.35 / 243.8
6.05 / 244.1
Genny / charger off for half an hour, amps dropped to 239.5 in half an hour. Started main engine / alternator / smart (3 stage regulator).
Ran for 15 mins, capacity rose to 242.7 Amps. Charge could be seen to be slowing down as voltage rose to regulator set point of 14.3V.
It's now 40 minutes later and voltage is at 12.73V, and charge is 234.8 A.
Annoying if they are duff because they were only installed March last year. Eleven month layup may be to blame but still.
This what happened:
4.45 / 242.5
5.15 / 243.4
5.35 / 243.8
6.05 / 244.1
