Would you buy a silent Seagull? The Torqueegull...
Greenheart
29 Dec 2010
Warning: totally insincere thread. Unlike all my others... :rolleyes:
Imagine the scene...a windless, cloudless summer morning; two hours till high water in one of our big natural harbours; dayboats on moorings, hoisting sails that don't stir, and the noisiest thing around is the squabbling ducks and water dripping off old Ben's oar-blades.
Until...oh Good Grief! Old Ben's found twelve quid in his turn-ups, and spent the lot on a Seagull outboard at the seaboot sale...and, how dare he? He's going to destroy the blissful atmosphere of this perfect morning, with two-stroke smoke and more racket than Wimbledon.
Just imagine if Ben turned out to be a volt-vamp, and had shoehorned the workings of an electric outboard inside the distinctively archaic form of the British Seagull. After all, the most appealing thing about Seagulls was always the b&w pictures - very trad, very quiet.
If anybody starts rebuilding Seagull outboards to run on electricity, please remember, you read it here, first...:rolleyes:
I suppose he's got a 235 amp/hour battery in the shoulder-pack...tough guy.
Been done a few times in the states with 10hp Hondas. But an electric Seagull would still find a way to make enough noise to wake the dead. Plus you'd have to turn the switch on and off three times before it would start.
I suppose you could probably dress a Torqueedo up by bolting a Seagull flywheel and fuel tank on top without too much difficulty. Would look the part at a distance. Perhaps one for the "Spirit of Tradition" types :)
Or how about 'Oartomatic Power'? The business-ends of a couple of these, slotted into holes routed into your oar-blades...
...a pair of foot-switches under the stern thwart, a couple of mid-weight batteries under the rowing seat, and off we go...
...and people on the quayside remark how "these old-timers may look a bit past-it, but they surely make their boats move, with barely a stroke on the oars..."
Not quite sure how it would be advantageous to locate the propellors in the oars rather than the transom...but perhaps electric sculling might be the answer?
The Bangkok Klong long-tail boats have the idea, though I can't see 007 powering away on a date with Britt Eckland using 12volts...Miss Goodnight wouldn't stay awake long enough to live up to her name. :rolleyes: Has to be worth a try, though...
Britt-ish See-girl
I believe I'd put her in charge of turning things on...
...works for me. Very ampowering. Watt? Watt's wrong with that? She understands + and -, male & female parts. :rolleyes:
I remember somebody, probably Bill Beavis, describing how it was possible to end up hand-cranking a Seagull-powered tender from the quayside, all the way to your mooring, without it ever starting. And I think that was on a model before recoil starters were fitted...
...but maybe there'd be a nifty, green solution to dinghy propulsion in that; some kind of ratcheting coil-spring fitted inside the Seagull (take out all the petrolly components)...and you can 'wind-up' the spring using the recoil start, sufficient to turn a big slow-ish 12" prop, giving the dinghy about five foot of progress before it's necessary to do it again! Beats rowing, doesn't it? Doesn't it? Oh. :o :(
