fishermantwo
I too am mistified to this statement.Personal EPIRB with integrated GPS has to be the best solution if only because the human factor element is eliminated when it comes to determining and passing the position.
That would be true, the personal EPIRB is the best and if it has an intergrated GPS all the better. This is something similar to what aircrew of my period used but with out the GPS. Called SARBE it emitted a signal like the old style EPIRB. Aircraft flew down the bearing till they found you. It had the added advantage of short range two way communication.
My apologies to those confused by my statement above that EPIRBs crap over mobile phones and handheld VHF. I was using plain English but will try speaking slowly. EPIRBs are far superior to mobile phones and handheld VHF. Mobile phones have saved peoples lives locally but they dont give a bearing and can only be narrowed down to a cell. One splash and they are rat [--word removed--]. Handheld VHF are limited to line of sight and 5 watts and can be homed in on. EPIRBs are line of sight also, but commercial aircraft along the Australian eastern seaboard are transiting at about 30,000 feet. If you are treading water that gives your EPIRB a range of 225 miles. If you are treading water with a handheld VHF and the rescue boat has an aerial 20 feet high expect a range of 5.8 miles. The reality though is these ranges are often much further than that, especially in the EPIRBs case.
