seaesta
My prop shaft has a lot of slack (on the hard there is movement when the prop is grasped and pulled up/down and side to side). Natural thought is to replace the bearings. The boat is a Westerly 25 and I suspect the bearings remain untouched since original launch in 1966.
There are two bolt heads on a metal plate on the skeg where the prop emerges and I assume the right approach is to remove the shaft and then these bolts and then try and pull out the old bearings. Has anyone done this job before and can they advise on tricks/techniques for replacement.
Martin
Martin
