Wooden mast
dualin
20 Jul 2008
Boat Pin Mill Me? where the fun is
Wooden mast
I need a mast for a 20 ft lugger as I have snapped it again so a bigger one is needed ,something over 24ft long and about 6 inches diameter. An old smacks boom or bowspit will do
__________________
Nil-Desperandum or go to the Pub for think
Get a life get a Lugger
tonijon
2 Jun 2010
east coast can be found most weekends at the Black
if you want to outlay on a new one oer the old one is repairable can highly recommend james brayn shaw he is a camper and nick trained shipwright does all the spars for the tideway dingies and has made rigs for upto 60ft yachts amongst others his quality of work is second to none. He is based at heybridge basin behind the tiptree tea rooms in clints yard.
DownWest
25 Dec 2007
S.W. France
Or, with winter coming on, build a new one with the birdsmouth technique. There are several sites explaining it, google Duckworks. It allows for less than perfect long lengths, as you can scarfe the staves. Can be done with a simple bench saw or, in my case, router table. Mast, boom and yard all done this way on my Oughtred boat, very satisfying as well.
A
dualin
20 Jul 2008
Hi I have found a source of good mast makeing material --- a telegraph pole !! i have found out these come in 3 sizes light -medium and stout ,I have gone for a light as i need a 6 meter lenth and they are 5" at the top and 6" inches at the bottem and the best bit is i have found out where the come in to the country so i have got an un creosoted one and all very cheaply . i now need to plane it to the the right size and i have to remove 3/4" all over and keep the thing straight any idears???
electrosys
23 May 2009
Boston - gateway to the North Sea (and bugger all
For poles: Calders & Grandidge, Boston.
http://www.caldersandgrandidge.com/products_poles.htm
Skim the pole with a router. Make up a jig from long lengths of angle-iron, strap 'em to the pole. Run the router along the pole making a series of 'castellated' grooves (like a series of machined splines). Then remove the material from between the grooves. Then start sanding ....
