Bassplayer
Ok one for you clever people! I have been looking at a Fairey and decided to buy a moisture meter to check moisture levels. The boat in question has been out of the water and in a modern industrial unit for over 3 months. I took some readings from the decking at home (5 years old and untreated from new) and got a reading of about 13-15% to give me a starting point to work from. On the boat the readings for the deck were about 15%. Inside the saloon and aft cabin below the windows between 20 and 30%, with a couple of places off the scale at 45%. The bilges taking a reading from the keel hog 25% and inside the hull 25%. Being a bit worried by the relatively high readings I tried the outside of the hull above the waterline and got a reading off the scale all round (over 45%) Much the same below the waterline, although that was a bit better in places. The hull has been expoxied below the waterline.
Now I know that there is some controversy regarding meters, but does anyone have any thoughts on this before I walk/call a surveyor? Is the paint holding in the moisture on the outside or is the paint "confusing" the meter?
Over to you!!
Over to you!!
