bekasi
Active Member
Whats the life span of a properly constructed wooden diesel inboard vessel? Pros/cons of timber?
Hi mad boater,
Thanks...its info for a friend wishing to have one built.By wood I meant wood on the inner but heavy matrix of glass fibre and epoxy resin...it does look like GRP as the end product.Picture attachrd
After a decade of owning and cruising a wooden boat, I must second 100% your above statements.nothing wrong with getting a timber boat but i wouldnt have it glassed..
and yes their require alot of up keep.but can be very rewarding..
hmm.the only trouble i think with glassing wood is...
you end up with water between the the glass and the wood and it tends to rot the boat quicker!!(you will get water in the bilges from sturn glends and so on).
timber boats have have their own identiy, not very often you get two the same..
best of luck anyway.
LOL, thanks for the appreciation, but actually I wouldn't call my own experience with wooden boats so extensive, really.Other than that I find myself in the very dangerous position of dis-agreeing somewhat with MapisM and his rather extensive experience and knowledge as well as yourself.
There are Fairey Marine boats still around that are approaching 60 years old with no major problems. However, they weren't stuck together using epoxy and were made of good hardwoods.what's the age of the oldest fairey-levi's etc?
are we all talking about a woodern boat getting glassed over?
or a grp boat with a bit of wood?
i was talking mainly about glassing a proper woodern boat..
so why build boats in this way?
