dombuckley
Unfortunately we have to agree to disagree on this issue.
Regards
John
+1
Only last month I surveyed a yacht planked with 30mm iroko. It was in pretty much A1 condition, except for localised heavy decay around the seacocks, which had been bonded to the anode. Some of the decayed sections were so soft that the valves showed substantial movement when pushed. Luckily they had been well-maintained, so required very little effort to operate: had anyone had cause to try to "persuade" a seized valve, it may easily have pulled through the planking.
Iroko seems particularly prone to electrolytic decay, but the action takes place in all timbers to some extent, particularly oak and phillipine mahogany. Older teak and pitch pine seem quite resilient, but the "sustainable" teak currently available commercially doesn't seem to have the same resistance.
As with John, I have also found this a common problem with timber (usually plywood) backing pads on GRP yachts.
Bonding seacocks to the anode was a "bright idea" that arose about 20 years ago, probably as a response to the use of brass rather than bronze below the waterline. However, as the MAIB report into the near-sinking of the Sea Harvester a few years back makes clear, it causes more problems than it alleviates.
Dom
