Wood identification ?
Boo2
13 Jan 2010
Hi,
I'm going to make some lockers in place of either one or both of Sunrunners' pilot berths and I need to identify the wood type and finish of what's already there so as to match it (see attached pix). I only needto know the veneer type since I'll be using veneered ply for the new bits anyway.
Anyone care to hazard a guess as to what the wood is, and what finish would come closest to matching the original ? I will probably re-finish the whole lot anyway but am quite happy with what's already there - just a brush up would do me.
Thanks,
Boo2
I would say it's teak, and for a finish you may need to play around with a stain to match the old wood and a flat varnish (Epifanes rubbed effect is very good).
As Plankwalker said.
You might want to thin the varnish down and, when dry, give it a rub with a scotchbite pad and Danish Oil to finish. Do a couple of small test pieces.
It is teak - commonly used for fitting out boats in that era. You can get it from Robbins in various grades of ply, but interior work is usually in veneered one side on WBP. finish with satin varnish - I have found Ronseal satin just as good for interior work as any of the fancy stuff - cheaper and easier to apply and very durable.
Brave men giving confident diagnoses on the basis of your photos. Looks like some of the stuff I've seen called teak. It sure doesn't look like any of the teak I've got lying around. If it wasn't on a boat I'd guess it for one of the rosewoods. The ribbon grain, though atypical, could be mahogany or one of several mahogany substitutes - it doesn't look mushy enough in grain definition to be sapele. There are then a bunch of exotics that it could be - not unlike a lump of bubinga I have waiting for the lathe.
If you buy a nice bit of teak faced ply from Robbins it'll look lovely anyway.
Astoundingly assured thread. I have examples of all the woods mentioned - and probably a dozen others. I wouldn't feel qualified to judge on the basis of the photos even though I can take my laptop out to the workshop and hold the photos beside timber samples. I have three "teak" tables which I scavenged for the timber. One is clearly teak. The other two clearly aren't - you can tell instantly from the smell when you cut it. One might just be a manky bit of iroko. The other is a mystery - but it is pretty naff. I have a beautiful lump of afrormosia - it could fool me for teak any day apart from the smell. Of course it could be marketed as "African teak". A couple of renewed strips of my cabin sole have been replaced with afrormosia. It looks more like teak than teak I'd say - if anything oilier - bet it would fool you.
(This is what's known as a smart-ass post.)
