Roach1948
I seem to be having a problem with my new for the season (old) furling gear. It is a Merriman system similar to a size 3 Wyckeham Martin. From the Stem to the cockpit it is about 4.5 metres, so I decided since it was not far, to get 6 metres of 8mm braided line; the thinking was that it would be easier to handle. This is about all the drum could take, and when winding the sail up, it transpired I did not have a long enough length, as the bitter end ran up to the stem each time. Then I decided to go 6mm at 7 metres, and the same still happens. Now I have got 10 metres of 5mm and although the problem is vastly reduced, all 10metres can get would in on occasion.
It seems to me that in fresh winds the sail unfurls very quickly and this for some add reason feeds more line than in slower wind speeds. I wonder if I have set it up all wrong and whether others have this issue with WM gear?
It is usually in strong winds that I don’t want to go forward to sort out a mess, and I am now going up there as frequently as I did when I had hanked sails!
