Cloven
I have had a persistent problem starting my Yanmar 2GM20F and a Yanmar service centre has suggested fitting a starter relay. I have obtained the relay, a Durite 0-727-12 12v/30A and they gave me these instructions:
terminal 30 +ve power supply to relay (from starter main terminal)
terminal 87 +ve from relay to solenoid switch (replaces white wire)
terminal 86 white yanmar start wire
terminal 85 -ve (negative)
Below is a diagram of what I think is the correct wiring.
[/URL]
Couple of question:
1. Does this appear to be the correct wiring?
2. Where should the relay be sited - closer to the starter motor or to the push button switch? or does it not matter - latter is easier.
3. Should I run a new +ve wires from the starter motor and solenoid to the relay or can I use the existing ones in the wiring loom? If the former, then I assume I would add a new fuse as per the diagram.
NB (I have a Blue Sea 30A Mega Fuse which I planned to use to replace the existing Yanmar one in the wiring loom anyway as it is so inaccessible)
Any advice on gratefully received.
Couple of question:
