DavidMcMullan
Coming from a GPS antenna I have the following 8 cables. Can you please confirm which need to be connected to the Raymarine 85001 box and where.
GPS RX+ - NMEA-0183 signal received from plotter
GPS TX+ - NMEA-0183 signal transmitted to plotter
GPS RX- - signal ground
GPS TX- - signal ground
GND - signal ground
Shield
Diff In - RTCM-SC104 signal from DGPS Beacon receiver
GPS PWR +
I have 12V connected to GPS PWR + & GND.
Do I connect the TX (+&-) to the 'NMEA in' terminals?
Do I need to use the RX (+&-) ?
Also Is there a problem with having two GPS antennas connecting into the system at the same time?
Thanks.
GND - signal ground
Shield
GPS PWR +
Thanks.
