I have a strong feeling you are right Vic! I didn't follow it closely where it went from battery one and suspect (now I think about it) that it just passes close to the back of the 1 2 Both and into the engine compartment.....The negative connection to the 1,2, both, off switch is not right surely?
Me thinks their would be a big bang if it wasThe negative connection to the 1,2, both, off switch is not right surely?
The diagram show what I have added to my two battery system with a 1 2 Both switch. I use either battery as the start battery, and just alternate, the other battery then being for domestics. Theyt are equal size leisure batteries, (sealed lead acid). The circuits I have added are the ones shown, I have left off the normal stuff to the engine and switch panel.
So, over time I have added
1.solar
2. a diesel heater
3. a power socket
4 and 5. new circuits for VHF AIS Masthead lights
Everything works okay
My question is should things be improved in any way. I will add to that in a bit.....
Thanks. I left out the fuses for simplicity for the diagram. Every circuit I have added has an inline fuse on the positive (supply). ( I am confident of my wire sizing and fuse rating). My only exception was for some reason I put the fuses for the solar on the negative returns to the batteries,and I need to change that. But I can redo the diagram is due course - it obviously needs one correction.....Not elegant, but that matters much less than whether it is safe. If you draw in the fuses (assuming there are some!) you can get an opinion on safety.
Thanks PeteK. I can see I could reduce the number of negative returns. It really illustrates how I added one project each year or so.All the negatives look too complex,wire them too a common busbar,engine block should be wired too negative.on batteries.
Great to get your input Ole Will! I'd like to get rid of the 1 2 both but I am used to how things function as they are. I do avoid the Both setting.I think the basic arrangement is OK. What is important is to understand and remember how it all works and particularly that VHF and diesel heater are hard wired to one battery. This means no isolation switch for safety when leaving boat for this part of circuit. I would always prefer a starter battery and servicee battery with VSR to get engine charge. But you obviously do not want to start changing things around and are happy to manage 1,2,both switch.
Just do not get into the habit of starting and running on "both". Time will come when one battery dies and will not start engine. In both you will not know there is a problem until the other battery dies. Start on one then later the other at least occasionally to ensure each battery alone is up for engine starting.
I agree that is what I would like to do, but so much easier to write it than for me to execute it - time and skill levels are against - particularly skill levels . But I aspire in that direction!Time to consider using those 2 batteries as a house bank and getting a separate engine start battery (simple 60-70Ah car battery) with a charge splitter such as a VSR from the engine alternator. Do away with the 1,2 both and switch each bank individually with a means of connecting the house bank to the engine in an emergency. Wire your solar just to the house bank. A distribution panel for the house bank for all domestic loads such as lights, nav lights, electronics, heater, power sockets USB. Much simpler, no need to switch from battery to battery, both banks are charged automatically from the alternator and the solar tops up the house bank,
Dare I say it - but if I can do it (and have done twice) it can't be difficult. Perhaps Paul will let you have a copy of his model wiring diagram and you will see how easy it is.I agree that is what I would like to do, but so much easier to write it than for me to execute it - time and skill levels are against - particularly skill levels . But I aspire in that direction!
Thanks Tranona, I've seen your very tidy switch panel piks and followed this issue from the sofa for ages so to speak,. I was just about to reply to Paul and say exactly your point..... I need a wiring diagram to follow and I have never found one .....so genuinely it would be great Paul if you could let me have a copy. Appreciate you have been championing this a long time.Dare I say it - but if I can do it (and have done twice) it can't be difficult. Perhaps Paul will let you have a copy of his model wiring diagram and you will see how easy it is.
